Help Please
Friends,
I purchased Marcos relay system and found the quality of the relay and instructions best of class. I installed the relay kit as instructed, started the car, put on the headlights and they worked beautifully. I then switched on my highlighs and the head lights went off again. I then put the turn signal stalk back in the low beam mode and . . . still no lights again low or high.
Prior to installing the relay kit, my headlights would not come on and my turns signal flashers would blink about 4 times and then both would come on like hazard lights.
1. Changed my ignition switch . . . . and lights came on for a while then gone again until relay switch installed.
2. Checked fuses and headlights and both are OK.
Is there any recommendations to cure or can anyone helpme trouble shoot this? My thoughts are that my turn signal switch is the root of all evil.
M-74
Old 10-23-2007, 11:46 AM
AutoBahned
RWebb's Avatar
check all the ground stars nearby - pull apart, clean, treat with strong vinegar 'till shiny, then use dielectric grease for re-assy
search on all terms above for more info
Old 10-23-2007, 03:09 PM
When this happened to me I found that the turn signal switch had failed.
1981 911sc Targa Rosewood (sold to Rob)
1983 911sc sunroof coupe Guards red
1986 930 (Sold, but not forgotten)
Old 10-23-2007, 04:52 PM
