Valve Guide Replacement wo/top end?
Is it possible to renew the valve guides on a 3.2 without doing the top end [valve job]? Do you need to drop the engine to do the guides?
thx |
no and yes.
Evolved
Replacing valve guides will move the "center point" of your valves. Valves and seats must be re-cut to re-center everything and regain proper seal.
You might possibly remove and re-install your heads with the engine in the car, but you will wish you hadn't!
Don't fear the reaper. |
Thanks and 'got it'. I'll just live with that little puff of smoke on startup after it sits. It only lasts 5 sec or so. Engine only has 67k on it
todd 89 targa |
My car does that and it is consindered normal unless its smokes longer
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
So if it smoke for coupld secs start up, it is the valve guide problem? I thought any old car does that.
Fat butt 911, 1987 |
No that is not a tell tale sign. Ultra high oil consumption and smoking on decel is. At least it was on mine.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) Last edited by Super_Dave_D; 10-23-2007 at 05:07 PM.. |
Agreed... a light puff on startup is normal for these cars.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Here's how I think it works after reading here for awhile ( from winter of 2002). The guides get worn and let oil into the cylinders which shows on start-up. While this is going on, the valve and the valve guide are now becoming more that just a concentric seat. This works for a while longer (maybe 100K miles) but you now have total junk for heads, Every seat must be replaced along with every valve. Not to mention the cause of it all, the guides.
Isn't an oily spark plug another indicator?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
I brought my 3.2 to to have a ticking sound checked out by my local independent recently. He told me me I have a worn guide and the valve is moving around. The ticking is not as pronounced when warmed up. The valves were adjusted about 4k miles ago. The cars runs fine with no smoke. I only use about 1/2 to 3/4 quart per 1000 miles. I was told this is normal for a higher mileage motor (110K) and just drive it for now. Should I expect higher oil consumption soon? I'm wondering if a top end job is going to come sooner than I expected.
1987 911 Carrera 2006 Audi A3 |
