Valve Guide Replacement wo/top end?
Is it possible to renew the valve guides on a 3.2 without doing the top end [valve job]? Do you need to drop the engine to do the guides?
thx
Old 10-23-2007, 11:19 AM
no and yes.
206 637 4071
Old 10-23-2007, 11:22 AM
Evolved
Mo_Gearhead's Avatar
Replacing valve guides will move the "center point" of your valves. Valves and seats must be re-cut to re-center everything and regain proper seal.
You might possibly remove and re-install your heads with the engine in the car, but you will wish you hadn't!
Don't fear the reaper.
Old 10-23-2007, 11:42 AM
Thanks and 'got it'. I'll just live with that little puff of smoke on startup after it sits. It only lasts 5 sec or so. Engine only has 67k on it
todd
89 targa
Old 10-23-2007, 03:06 PM
FenderGuy's Avatar
todd
89 targa
My car does that and it is consindered normal unless its smokes longer
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 10-23-2007, 03:14 PM
rnln's Avatar
So if it smoke for coupld secs start up, it is the valve guide problem? I thought any old car does that.
todd
89 targa
Fat butt 911, 1987
Old 10-23-2007, 03:24 PM
Super_Dave_D's Avatar
No that is not a tell tale sign. Ultra high oil consumption and smoking on decel is. At least it was on mine.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 10-23-2007, 05:18 PM
TroyGT's Avatar
Agreed... a light puff on startup is normal for these cars.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 10-23-2007, 05:23 PM
Zeke's Avatar
Here's how I think it works after reading here for awhile ( from winter of 2002). The guides get worn and let oil into the cylinders which shows on start-up. While this is going on, the valve and the valve guide are now becoming more that just a concentric seat. This works for a while longer (maybe 100K miles) but you now have total junk for heads, Every seat must be replaced along with every valve. Not to mention the cause of it all, the guides.
Old 10-23-2007, 06:09 PM
khamul02's Avatar
Isn't an oily spark plug another indicator?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 10-23-2007, 06:24 PM
I brought my 3.2 to to have a ticking sound checked out by my local independent recently. He told me me I have a worn guide and the valve is moving around. The ticking is not as pronounced when warmed up. The valves were adjusted about 4k miles ago. The cars runs fine with no smoke. I only use about 1/2 to 3/4 quart per 1000 miles. I was told this is normal for a higher mileage motor (110K) and just drive it for now. Should I expect higher oil consumption soon? I'm wondering if a top end job is going to come sooner than I expected.
1987 911 Carrera
2006 Audi A3
Old 10-23-2007, 07:16 PM
