Rear Swing arm damaged?
Trying to remove old swing arm bushings on an aluminum trialling arm. Is there a hole that runs down the middle of the arm from inside where you would put the new bushing. While removing the inner cups I might have damaged one of the inner races. There is a hole that looks like it is actually cast so maybe I didn't damage anything. But not for sure? If there is no damage I will continue with the monoball upgrade that I'm doing.
Old 10-25-2007, 03:49 PM
Maybe I'm not clear. After removing old rubber and bushings that rubber sits on I may have damaged the aluminium housing that the bearings ride on. Is there a hole that goes down the middle of the swing plate and does it open into the position of the old races?
Old 10-26-2007, 04:31 AM
Fritz Peyerl's Avatar
hole in swing arm
Pictures speak 1000 words. where are they????????????????
Old 10-26-2007, 06:00 AM
Evolved
Mo_Gearhead's Avatar
I too am confused as to what you are describing?
Don't fear the reaper.
Old 10-26-2007, 06:50 AM
