porsher
aston@ultrasw.c's Avatar
Shift Lever Mod
I have an 86 Carrera and I would like to move the shifter rearward but I can't afford a relocator kit at the moment.
So, is there any merit in removing the shift lever and bending it judiciously?
TIA
Old 10-25-2007, 01:00 PM
rberry951's Avatar
TIA
You must be short armed like me! I hate the fact that in proper driving posture I have to lean forward to shift. I wasn't aware there was a relocation kit! But I intend to do exactly what you suggest, either bending the sucker, or replacing it with something else all together that I can reach. I've come to the conclusion that this is a common complaint. Maybe one of our machinists on the forum could produce a more effective shift lever alternative, maybe build a short shift kit into it?
Just my thoughts...
Regards,
Russell
Russell Berry
1986 911 Carrera Targa Widebody/Slantnose
Old 10-25-2007, 01:09 PM
porsher
Hargett Precision Pro 915 Shifter HP-915-SHIFT-B
Maybe I'll get a short shifter for a 100 bucks and tweak it. Then if anything bad happens I can put the stock one back in.
Old 10-25-2007, 01:24 PM
TIA
Do this in the car so you know how far to bend and to what angle, but only if you're careful with the gas welding tip. Use a hot flame so the heat doesn't migrate to the bottom and distort the shifter bushing.
Do this outside or in a safe working area.
Use plenty of protection (welding blanket, real thick gloves, etc.) and have a fire extinguisher ready, just in case.
Heat the lever away from the seats (1st/3rd/5th), then confirm.
There's a limit based on how close you want the lever next to your leg or seat in 2nd/4th/Rev (915).
An extension welded to the lever will bring it closer to the steering wheel but increase the throw distance.
A tall gear shift knob clamped to the highest location on the lever will extend the lever a small amount. It's slight, but noticeable.
Sherwood
Old 10-25-2007, 01:35 PM
Lets not forget the fuel line running thru the tunnel..this could make for a very bad day.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 10-25-2007, 05:54 PM
