Send a message via AIM to Adidas
Confused about correct 911 tire pressures
I have a 93 911 Cabriolet with Continental Contisport Contact tires. The rears are 225/50/ZR 16's and the fronts are 205/55/ZR 16's. The factory sticker on the drivers inner door calls for 44lbs in the rear tires and 36lbs in the front. I have inflated all 4 at 36lbs and the rear tires are worn in the middle which looks like overinflation. Any ideas on proper tire inflation? Thanks Bill
Old 10-25-2007, 11:01 AM
Wash. State
nesslar's Avatar
I guess they don't show the inflation numbers in the rear under the lid anymore? 36/44 sounds like you are trying to explode the things. I would think that 30 front and maybe 33/34 rear would do you well. 44 sounds down right dangerous.
That wear is over-inflation indeed.
Old 10-25-2007, 11:09 AM
joe payne's Avatar
29 front 34 rear
jtp911
Old 10-25-2007, 11:22 AM
Don't forget 29/32-34 while the tire is cold
1982 SC
Old 10-25-2007, 12:20 PM
KTL KTL is offline
Schleprock
KTL's Avatar
36/44 sounds like the numbers for 17 inch tires.
Kevin L
'86 Carrera "Larry"
Old 10-25-2007, 01:50 PM
Try your question on the 964 board.
Old 10-25-2007, 02:11 PM
Senior Member
Superman's Avatar
Tire pressures are interesting. These days, I run something like 32/34 mostly. Autocross pressures are usually somewhat higher, but it all depends on the tire.
Tires wear down mostly due to heat. That, rather than tire pressures, is why they wear in the middle. Low tire pressures allow for more flex, and more heat.
Mocha 1978 911SC. "Coco"
Old 10-25-2007, 02:23 PM
cold: 30/36. I go with factory rec.
87 blk coupe
Old 10-25-2007, 03:39 PM
