Part ID?? installing MSD on an SC
Can you tell me what this is and if you have an idea of where to remount it? I know I'll have to remount the VR (unless I find the time to put in my new alternator, then I'll just skip the VR).
Any other tips appreciated--been looking thru the msd mount/install links and nothing about the fact that the msd does not fit on the plate of an sc without moving the VR and whatever this thing is.. I also looked on the parts diagrams on this site and couldn't locate it--can you? thanks in advance. Jack http://forums.pelicanparts.com/uploa...1193509387.jpg |
I'm pretty sure that part you are asking about is the rear defogger relay.
The relay can move, but you can also have the MSD hanging a bit off the far edge without any problems. I made a couple little throughholes for it into the tin. Just be careful that you don't block the holes needed to mount the tin onto the car.
In a minute or two, though, you're going to get pictures from others that have done BEAUTIFUL jobs making/adjusting new mounting positions and the like. Another data-point: I put the cover back on over the whole assembly without any intereference or overheating problems. Babak |
thanks Brian, that's it. And Babak, I've seen the install pix...pretty impressive but it didn't seem to help me out with where I am in the process now.
But how can you have the msd hanging over the edge when the stud holes are right along the edge of the msd? |
| All times are GMT -8. The time now is 07:30 PM. |
