-   -   Starter problem (http://forums.pelicanparts.com/porsche-911-technical-forum/374571-starter-problem.html)
sbmackie 10-28-2007 08:12 PM
Starter problem
Drove car today, got pretty warm for a couple hours (220-ish), stopped once along the way, car started normally. Got home, parked in driveway for a few minutes. Came back out, tried to start. Just got a buzzing noise from center/rear area.
Starter or solenoid Kaput?
Scott
9dreizig 10-28-2007 08:17 PM
Sounds like maybe low voltage. First check all of your battery connections, you'd be shocked what a poor connection can do ( at both the battery as well as the main power on the starter)
sbmackie 10-28-2007 08:48 PM
voltage
OK, Ill check that. All the electrical bits are coming on strong, and are "dimming the usual amount" as a normal start.
sbm
911Rob 10-28-2007 11:07 PM
I was going to say solenoid, having experienced this with other cars in the past?
Apparantly when warm/hot it effects the solenoid; try it once it cooled down?
My 2 cents?
katigbr 10-29-2007 08:05 AM
I had been having intermittent starting problems over the last couple of years in my '66 and was getting worse and worse. I checked all ground and connection point voltage until it we tracked down a voltage drop in the circuit between the ignition switch and starter solenoid.
I ended up wiring a secondary "Start" button and relay directly to the starter as described in a few other threads. Works like a charm. You can see the new button on the dash where the lighter used to be.
http://forums.pelicanparts.com/uploa...1193670307.jpg
Regards,
sbmackie 10-29-2007 09:51 PM
It started
After cooling down, it started normally. I assume it was a stuck solenoid from the heat.
Will replace at next opportunity. Thanks for all the advice!
Scott
911Rob 10-29-2007 10:32 PM
http://forums.pelicanparts.com/uploa...1193722331.gif
