sbmackie's Avatar
Starter problem
Drove car today, got pretty warm for a couple hours (220-ish), stopped once along the way, car started normally. Got home, parked in driveway for a few minutes. Came back out, tried to start. Just got a buzzing noise from center/rear area.
Starter or solenoid Kaput?
Scott
Old 10-28-2007, 08:12 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Sounds like maybe low voltage. First check all of your battery connections, you'd be shocked what a poor connection can do ( at both the battery as well as the main power on the starter)
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-28-2007, 08:17 PM
sbmackie's Avatar
voltage
OK, Ill check that. All the electrical bits are coming on strong, and are "dimming the usual amount" as a normal start.
sbm
Old 10-28-2007, 08:48 PM
Canadian Member
911Rob's Avatar
I was going to say solenoid, having experienced this with other cars in the past?
Apparantly when warm/hot it effects the solenoid; try it once it cooled down?
My 2 cents?
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 10-28-2007, 11:07 PM
I had been having intermittent starting problems over the last couple of years in my '66 and was getting worse and worse. I checked all ground and connection point voltage until it we tracked down a voltage drop in the circuit between the ignition switch and starter solenoid.
I ended up wiring a secondary "Start" button and relay directly to the starter as described in a few other threads. Works like a charm. You can see the new button on the dash where the lighter used to be.
Regards,
Rick Katigbak
Gretchen - 1972 3.6 ST-Replica
No Name - 1966 911 - 2.7S powered
Old 10-29-2007, 08:05 AM
sbmackie's Avatar
It started
After cooling down, it started normally. I assume it was a stuck solenoid from the heat.
Will replace at next opportunity. Thanks for all the advice!
Scott
Old 10-29-2007, 09:51 PM
Canadian Member
911Rob's Avatar
Rob McKibbon
Old 10-29-2007, 10:32 PM
