Injectors stick !!! Help
I bought 3.2 engine not being used for a couple of years. It turned out 3 from 6 injectors do not work. Is there a way to make them work again ? I'd rather not buy new :)
Marcin |
Do a search here on the Board. There are companies that will clean and calibrate your injectors.
Otherwise, try running a couple of bottles of Techron thru the system and see if it cleans up the injectors. |
a lot of folks like Witchhunter
http://www.witchhunter.com/
People seam to have good luck with these guys. Todd, Minneapolis, MN 1987 Targa |
We use RC Engineering and they are very good.
I think I read somewhere: The 3.2's batch fire 1/2 of the injectors at a time. Could it be that your not getting a signal on one bank? Might check for injector signal, or, try switching one of the known working injectors with one of the suspect injectors.
Hope this helps, |
I've had good success freeing sticking old injectors with carburator cleaner and 12V jolts.
Thanks! I checked the signal and it's fine. I put injectors into pot full of STP's injectors cleaner. I leave them there for next 48hrs. We will see what happens.
I just had the same problem, we cleaned, tapped them and did the 12V jolts. Have been running alot of injector cleaner through the system, they seem to be working.
| All times are GMT -8. The time now is 05:12 AM. |
