Injectors stick !!! Help
I bought 3.2 engine not being used for a couple of years. It turned out 3 from 6 injectors do not work. Is there a way to make them work again ? I'd rather not buy new
Marcin
1976 3.0 Carrera sold
1975 2.7 backdated to 73' RS
1971 2.2 T Targa
Old 10-29-2007, 08:10 AM
scottb's Avatar
Do a search here on the Board. There are companies that will clean and calibrate your injectors.
Otherwise, try running a couple of bottles of Techron thru the system and see if it cleans up the injectors.
1984 Targa
Old 10-29-2007, 08:11 AM
Yes it runs
tsiegwart's Avatar
Send a message via AIM to tsiegwart
a lot of folks like Witchhunter
http://www.witchhunter.com/
People seam to have good luck with these guys.
Todd, Minneapolis, MN
1987 Targa
Old 10-29-2007, 08:45 AM
We use RC Engineering and they are very good.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-29-2007, 09:45 AM
Goth's Avatar
I think I read somewhere: The 3.2's batch fire 1/2 of the injectors at a time. Could it be that your not getting a signal on one bank? Might check for injector signal, or, try switching one of the known working injectors with one of the suspect injectors.
Hope this helps,
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 10-29-2007, 10:26 AM
I've had good success freeing sticking old injectors with carburator cleaner and 12V jolts.
Old 10-29-2007, 11:31 AM
Thanks! I checked the signal and it's fine. I put injectors into pot full of STP's injectors cleaner. I leave them there for next 48hrs. We will see what happens.
1971 2.2 T Targa
Old 10-30-2007, 02:26 AM
beamonk's Avatar
Send a message via AIM to beamonk
I just had the same problem, we cleaned, tapped them and did the 12V jolts. Have been running alot of injector cleaner through the system, they seem to be working.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 10-30-2007, 05:09 AM
