Zeke's Avatar
A better trombone oil cooler?
Old 10-28-2007, 09:01 AM
Designer King
Paulporsche's Avatar
I like it. Does it come w/ AN fittings?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-28-2007, 10:28 AM
Danny_Ocean's Avatar
I was thinking of the same thing recently. Using copper plumbing, constructing a trombone cooler with a few extra passes.
Old 10-28-2007, 10:37 AM
Better think brass or aluminum. I picked some material at random. Close, but not exact comparisons:
Copper tube
1: OD
Wall = .065"
ID = .87"
weight = .7401 lbs/linear foot
Brass tube
.875" OD
Wall = .03"
ID = .815
weight = .2944 lbs/linear foot
Aluminum
1" OD
Wall, .083"
ID = .834
weight = .29898 lbs/linear foot
After this project, you will seriously think about putting two big a$$ batteries in the LF corner to balance the front end. In addition, there would be enough room and lots of airflow if you delete the RF wheel/tire.
Sherwood
Old 10-28-2007, 02:49 PM
rnln's Avatar
milt,
when you are ready to mount it on your car, let me know. I'll come and help. On the hood or engine lid? :lol:
Fat butt 911, 1987
Old 10-28-2007, 02:51 PM
Early_S_Man's Avatar
Porsche Crest
Goin' to need something more than the average 3.6 to get that cooler up to 150 mph, I guess!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-28-2007, 03:56 PM
Bland
unclebilly's Avatar
Sherwood,
Did you conside that the brass is roughly half the weight of the coppr because the wall thickness is less than half (and the diameter is slightly less). Copper and brass have very similar densities.
Old 10-29-2007, 06:32 AM
dtw dtw is offline
GAFB
That exceeds my 911 cooling needs - but if only I could convince my wife to let me install that in the house for my homebrewing setup...
Several BMWs
Old 10-29-2007, 07:18 AM
Of course not. Here's more accurate info. Brass is just a bit lighter.
Brass - rolled and drawn 8430 - 8730 kg/cu.m
Copper 8930 kg/cu.m
Thanks for the catch of sloppy research. Will be more thorough next time.
Sherwood
Old 10-30-2007, 12:08 AM
Brillo's Avatar
Awesome Milt
Ray H.
1979 911SC Coupe
2000 986
Old 10-30-2007, 09:46 AM
Ever jump a Porsche?....
78targa's Avatar
Dip that puppy into an ice bath and hook a keg up to it.
Instant cold beverage.
Casey
Road-rally, Targa Newfoundland junkie!!!
1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping
Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome!
Old 10-30-2007, 08:00 PM
