Here's another description from Warren:
If it tries to fire while starter is turning, but dies when ignition switch is released to 'run' position ... and, if your car has a factory alarm with keyed switch in the driver's door, then the alarm control module is highly suspect! There is a well-documented [in factory service manual]failure mode of the alarm module that disables the car from being started!!!
Brian
Old 11-01-2007, 01:02 PM
930turbo's Avatar
So the RPM limiter and alarm only affect the fuel pump relay, not the ignition? In other words, even if the alarm is active I should still have spark.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 11-01-2007, 01:43 PM
