Sleep Deprived and Grumpy
jwernquist's Avatar
Stubborn Grease Cap 82SC
Ok I got the Grease cap off. Im a little miffed, SC's have a hard line to the caliper so is it impossible to take
the hub off without removing the caliper and bleeding the brakes. Any suggesttions. ???
Thanks In Advance.
JW
jwernquist@wi.rr.com
262.215.6547
Old 10-31-2007, 07:57 PM
jwernquist's Avatar
Ok so a little more trying i got it off. Bearing is in bad shape. Now Im frustrated I can't get the caliper off without removing the Hard Fluid Line, didn't want to bleed the brakes. I hate doing that.
I am not familar with SC's so if you have any tips or another way about it please let me know.
262.215.6547
Old 10-31-2007, 08:20 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
First of all I would never open the brake lines and not rebleed when complete. You are removing the caliper so you are going to have to bleed a bit. To save you a full system bleed you can remove the caliper from the hard line with this tip. Find a piece of wood to place between the seat front and the pedal about HALFWAY depressed. This will prevent all the brake fluid from leaking out. You will get some BF leaking out of the hardline but it should not continue to flow and empty the reservoir.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 10-31-2007, 09:54 PM
jwernquist's Avatar
Ahh thats a great tip. Thanks Scott!! I knew I was going to bleed , I just didn't want to do it
262.215.6547
Old 10-31-2007, 09:58 PM
group911@aol.co's Avatar
Look at it as a great opportunity to flush the brake fluid. Most of us don't do it enough, especially in humid climates.
Thanks,
Bob
group911@aol.com
Old 11-01-2007, 07:32 AM
