update chain tensioner cost?
I have 1973 911 T Targa .Many people have suggested to upadate the chain tensioner. Any thought to what this might cost? ballpark number is OK.
Cros |
New over $450
Ebay $300 to $400 Theres on in the classifieds for under $350 I think? Carrera upgrade
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 Last edited by FenderGuy; 11-05-2007 at 02:04 PM.. |
Carrera or 930 tensioners?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
The whole kit, new from PP, is $795 for the parts alone. Finding used will be less but you need the oil lines, cam tensioner covers, and the pressure fed tensioners along with new gaskets, correct bolts and crush washers for the oil lines. Better off with a new kit IMO. Labor extra.
Tony G 2000 Boxster S |
I'm doing this right now and just ordered all my parts.
I've seen prices between $605 and $795 for the oil pressure tensioner kit. Just as important are the improved chain tensioner support arms - priced between $340 and $410 for both. If you decide to go the 930 route you'll save a little money, but you should still get the updated chain supports. |
Do you need to remove the engine to do the chain tensioner ? How big of a job is it ?
thnaks Cros
Cros |
tab above. You will find this article:http://www.pelicanparts.com/techarticles/911_carrera_chain_tensioners/911_carrera_chain_tensioners2.htm If you do not have already, a copy of "101 Projects for your 911" and a Haynes is a good investment as well (no Bentley for our '73s )
sudo apt-get purge 930
Are the 930 tensioners not problematic? I thought ALL pre Carrera tensioners had problems. I hope the 930 ones are fine, saves me a lot of money if so. I was planning on upgrading this winter. Does this mean I don't have to upgrade?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I don't think the money is much different (the 930 tensioners can be found for $484 + gaskets and nuts vs. $609 for the Carrera kit that includes everything. |
Everything unbolts easily. Just be carefull when you tighten the covers. Magnesium can strip easily. You can do it in an afternoon. Keep the chains very tight. I used a couple of small turnbuckles one end had an eyelet the other had a hook. You can buy the special tools but cheap works just as well. Buy the turn buckles and you will see what I mean. My engine is back to gether so I can't show you If you (or someone) can post a picture of your engine sans the covers I can sketch something in. If the chains slacken and skip teeth you will spend more time trying to figure out the timing.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
I already have the 930 tensioners so if the Carrera upgrade isn't necessary I can spend the money elsewhere.
The results of tensioner failure can be catestrophic; $1000 is good insurance against a $10k engine rebuild if you don't know for sure . |
GAFB
I believe updated idler arms were implemented in mid 1980. You should update with new or good used idlerr arms.
Several BMWs |
