Anyone else have problem with the fit of H4's
The fit of the H4 is not that good, the right side fit good but the left side did not.
I ended up snapping it in place without the gasket and trimming it to fit. What way worked for you? ______________ 1981 SC Coupe |
Lots of fiddling. I ended up adjusting the top tab a bit until it fit. You need to figure out getting the seal in. You don't e\want moisture in the housing. It will dull the reflective finish.
Scott '86 911 Carrera Coupe, PCA, PBC |
The gasket is in place, I trimmed it to fit
Thread Tools | |
Rate This Thread | |
