Jon Green
Guest
Posts: n/a
Correct spark plug gap for '76 2.7S?
The Bruce Anderson tune-up data for my car ('76 2.7S US 49 state) states W5DC with 0.55mm gap.
Okay, I have the Beru OEM equiv. & the box tells me the gap should be 0.7mm.
The Haynes tells me 0.7mm if ROW & 0.55mm for North America.
I look through my Brooklands reprints of 74-77 roadtests & the technical data states 0.7mm.
The car is US spec but now lives in the UK, so which gap to use? I am guessing the smaller gap is needed to pass a particular emission test & the wider gap may give better power.
With the emission requirements being pretty slack for a car of this vintage in this country which is the best gap?
Also, does anyone know why the US spec. cars make 10bhp less than the Euros?
Thanks, JG
Old 02-19-2001, 02:42 AM
Jens Wendorff
Guest
Posts: n/a
I have a '76 non-S, 165HP.
I use Bosch W5DC with 0.7 mm gap according to Bosch Catalogue and Owners Manual. The plugs come with this setting. Therefore, I assume the same is applicable for the "S", but I will try to verify.
Jens
Old 02-19-2001, 04:12 AM
Jon Green
Guest
Posts: n/a
Yep, that's my point. The Beru application book says 0.7mm.
My user manual states 0.55mm, but it is a US manual.
I know it won't make loads of difference but changing the plugs on a 911 is a little fiddley & I would like the plug gap set correctly.
Cheers, JG
Old 02-19-2001, 08:22 AM
Early_S_Man
Guest
Posts: n/a
Jon,
With 'conventional' plugs like the NGK B-7ES, BP-7ES, or Bosch W5DC, you can use a 0.028" to 0.032" gap. It is not actually critical at all.
Warren Hall
1973 911S Targa
Old 02-19-2001, 08:51 AM
