-   -   1st time removing an engine, any advice.. (http://forums.pelicanparts.com/porsche-911-technical-forum/376184-1st-time-removing-engine-any-advice.html)
POORSH 11-07-2007 04:20 PM
This will be the first time I remove an engine from a car (79SC). I've already gone over Wayne's book as well as the tech article on Pelican. Just wondering if anyone can offer any suggestions on what I should look out for, and what I should replace while the engine is out. Planning on putting the EGR on, valve adjustment, and check for leaks.
gtihop 11-07-2007 04:28 PM
I found it easier to remove the rear bumper, you won't have to jack up the back end as high. Only takes 15 minutes, worth the time.
Blanco 11-07-2007 04:43 PM
oil temp sender gasket.
oil cooler gasket
brass fittings for your pedal linkage
check and replace clutch/ fork/ etc. replace fluid as well.
a few more I can't think of right now.
