-   -   Engine dies while coasting-restarts slow. (http://forums.pelicanparts.com/porsche-911-technical-forum/37633-engine-dies-while-coasting-restarts-slow.html)
FRED/LI 02-20-2001 05:55 AM
Last week while on the LIE I thought i detected a flat spot while coming off a short coast at 50mph. When I depressed the accelerator, the car took a second to respond. It seemed like the DME system didn't want to reawaken. I know that it shuts off the injectors while coasting which is normal.
Yesterday, it just plain died. I pulled off and couldn't get it to restart immediately. Once I waited for about two minutes, it kicked over like nothing happened.
It's a '90 C2.
Any ideas? Thanks.
FRED
nhromyak@yahoo.com 02-20-2001 05:04 PM
Have you tried replacing the DME relay? This seems to be a simple and common "shotgun" approach.
Check and replace as appropriate all vacuum lines.
Good luck.
Nick
Nick Hromyak
'85 Carrera
