-   -   Pertronix Ignitor (http://forums.pelicanparts.com/porsche-911-technical-forum/376802-pertronix-ignitor.html)
911oslo 11-11-2007 07:51 AM
Pertronix Ignitor
Hi.
Some days ago i was planning on mounting the Pertronix Ignitor Electronic Ignition on my 1972 911E 2.4 EFI. I bought PEL-PT1863 as i thought it would fit my car.
When i was reading the instructions it stood that this kit only could be used on coils with more than 1,5 ohms. I measured my coil to 0,7 ohms.
Could i still use this kit on my engine, or do i need to modify something?
Iam also wondering if my engine has a ballast resistor?
I can only see that the - wire goes to the engine and the + wire goes to the ignition unit..
911oslo 11-12-2007 01:00 PM
Bump!
I tryed the search function, but did not get any help there..
cameron.arnott 11-13-2007 01:12 AM
911 Oslo
I installed the same model on my 2.4 engine with S dizzy, and black coil and it runs fine.
Give it a try, I think you will be ok.
Good luck
