Shakenbake
Guest
Posts: n/a
Source of mid range missing - found & Fixed!
I've been having an intermittent mid range sputter and missing problem since before I tackled the Carrerra chain tensioner update this past weekend. I finally traced the problem down to the plug wires. Using a digital multimeter,(Thanks Warren) I was able to determine which wires were not consistent. Found 4 plug wires that were not carrying their share and 1 bad connector. Replaced with some wire and connectors from a previous wire change and WOW! What a difference, Now I'm back to my old self...uh, maybe. Next project...hmm, turbo tie rods???
Chris
Old 02-21-2001, 03:28 PM
ClayMcguill
Guest
Posts: n/a
Chris, if you do decide on the Turbo Tie Rod update, be sure to stop by your local bike shop and pick a Park 32mm headset wrench-it's perfect for removing the nuts at the steering rack end. (Thanks to NickShu for that tool tip.)
Clay McGuill '66 912, '97 Jeep Cherokee www.geocities.com/the912guy
Old 02-21-2001, 07:25 PM
