-   -   Cornering Noise (http://forums.pelicanparts.com/porsche-911-technical-forum/37700-cornering-noise.html)
Fishcop 02-22-2001 04:23 AM
Cornering Noise
Can anyone suggest what is making a banging noise from the rear of my 69T? It usually occurs whilst cornering left or right at speeds above 20mph. I've been told it could be a CV joint or suspension. I think I can feel something through the steering wheel at the same time also. How do I tell if the CV's are shagged, can they be rebuilt or should I replace them with new ones? I have no sway bars (front or rear...will get around to these), and I'm pretty sure the engine mounts are fine. Any ideas or suggestion would be great, Thanks.
marc weintraub 02-22-2001 06:52 AM
Make sure you don't have a lsd that is going bad. Look for the obvious with the CV joint and suspension, but I had a similar situation that only occurred when I accelerated very hard or made a sharp turn to the right. My limited slip needed to be rebuilt. Hopefully, your situation will be a less expensive fix.
Marc
Superman 02-22-2001 07:24 AM
Mine makes a banging or thumping sound when cornering to the right. Single thump. Sounds like a loose baseball.
This is not a CV noise. Some have suggested it is a loose/worn spring plate bushing. Sounds like it's happening on the rear deck, right behind my head.
'83 SC
David W 02-22-2001 08:53 AM
I had exactly this problem with my 72E. Drove me crazy. Only happend on sharp turns. Turned out to be a bad inner CV joint. Ball was popping out of race.
robfix 02-22-2001 09:00 AM
Same thing while turning left. I'm hoping it is the cv joint as when I went to repack them they had serious pitting. On one the grove was so bad I don't think the ball could rol by, when it did I think it made the loud pop. I have the new ones and will install this weekend. I'll let you know if this eliminates the noise.
Rob Fix
'78 SC Targa
tcampbell 02-22-2001 09:51 AM
Just wanted so say thanks for bringing this topic up. I JUST started hearing this exact symptom on my car last week. You guys are great!
