Emergency brake light doesn't work
Car is a 1979 SC
Light never worked since I got the car a year ago Only worked once when the weather was very very wet. Not sure if it has anything to do with it. Maybe some water leaked inside and triggered something The 2 red wires have power ![]() Globe is ok I pulled the ground off the lever and grounded it, the light still didn't come on Thanks Rafik |
Member 911 Anonymous
Can your source a replacement light, mine did not work when I purchased it and replaced it and Bingo.
You verified power and ground so it must be the fixture
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hi karman,
This may not be your problem because the symptoms are opposite of what I experienced but if bulb (globe) replacement does not solve your problem you may want to look here. The light housing rests on the circuit board and can wear through the solder. I guess Porsche thought it would last 20-30 years not thinking we would keep these cars for 40+ years. Parking brake light always on Good luck, Rahl |
