Guest
Posts: n/a
quick ride height question?
Is the ride height supposed to be adjusted without anybody in the car? I notice when I am in, the left side compresses 1/4" lower than the left side. does this effect the corner weight loading? 81'SC
Guest
Posts: n/a
Yes, without people in the car. And 1/2 tank of fuel. I'm puzzled how the *left* side is lower than the *left*.
![]() ------------------ Tyson Schmidt 72 911 Cabriolet |
Guest
Posts: n/a
Lagoon,
here is a standard checklist to perform before a ride height adjustment: full fuel tank. proper tire pressures. center steering wheel/rack. 150 lbs. in each front seat. "bounce" vehicle a few times to settle suspension. -EJ |
Guest
Posts: n/a
Freefly, I have found that you end up sitting a little too high with this method. And if you set it up this way with a full tank of fuel, it seems nose high with a low tank. Half tank is a nice medium. Just my personal preference.
