Won't start, but is turning over
It looks like the car dos not get gas or don't get a spark. Its turning over nicely. Happen after 2 month storage. Please help on where to look.
Old 11-17-2007, 09:04 AM
Scott R's Avatar
And what type of car are we dealing with here?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-17-2007, 09:15 AM
Sorry its a 911T from 1969, all standard.
Old 11-17-2007, 09:24 AM
I'd first suspect the gas has leaked out of the carb float bowls--that's the simplest answer--and it will take a bit of cranking to refill them. Aside from that, do your simple diagnostics first. Check for spark (easiest thing to do), then check if fuel is entering the carbs throught the connections, and then if actually being "shot" into the throats when the butterfly is opened. Just sitting for two months probably resulted in a simple problem.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-17-2007, 10:52 AM
david dolan's Avatar
Hi,
When this has happened to me, I always check the fuel pump fuse, twice that has been the thing that was causing the problem.
David Dolan
1995 993 Carrera 4 India Red
1979 911 SC Targa Metallic Black
Old 11-18-2007, 11:54 PM
Thanks for your help, I will hope to fix it next weekend
Old 11-19-2007, 03:31 AM
