any suggestions? (pics included)
hey guys and gals...its been a while since i've posted. i recently moved to texas to start working for southwest airlines and have been getting situated before i started diving into projects for my 300k car. why try to fix up a 300k car that i bought when it had 270k? that's a really good question im still trying to answer myself. anyway, today i replaced the engine/tranny mounts. shifts alot crisper and the engine doesn't rock back and forth anymore, but i still get a klunk when engaging 1st gear quickly. perhaps thats something in the tranny. reverse is fine... maybe go to solid mounts? i don't go racing tho.
tomorrow is the bump steer kit, new spoiler lip, and a plastic dash if i get the time.
so my first question is the klunk in first gear....
my next questions are....WHAT CAN I DO ABOUT THIS: (it looks really bad)
i found the seal lip to go around the targa bar, but its like 200 bucks! do i have any other options? also, the vynl/leather below the seal that is torn...i couldn't find that anywhere...anyone have an idea?
Old 11-17-2007, 04:14 PM
915 transaxles make noise. Maybe you're had the worn mounts so long you've never had to experienced that noice
I'm not sure and I'm just taking a shot in the dark but, why can't you remove the trim piece, go to a "real auto upholstery supply shop" Find a piece of naugahyde and recover that piece?
If it can be done, use contact cement/ spray contact or brush on and coat both sides, let it dry then apply the new material??
Old 11-17-2007, 05:24 PM
Just glue it back on, as suggested above, with contact cement.
The fading on the Targa bar seal is easily addressed with permanent black magic marker (an Industrial Sharpy from Staples). You can carefully trim the loose threads if they're bothering you.
Or you can get all new seals and spend many frustrating hours trying to get it to seat right.
Good luck
Old 11-17-2007, 08:24 PM
barney911rs's Avatar
DO NOT use solid motor or transmission mounts on a street car. If this is strictly a street car as you seem to indicate, new stock mounts will be fine. If you want something a little stiffer, then use the sport mounts.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 11-17-2007, 08:59 PM
jonbot's Avatar
I'm interested in this thread because my '79 SC does this when I engage first gear. I've been told it could be worn out CV joints.
Jon
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 11-17-2007, 09:21 PM
hmmm....yeah mine isn't a noise, but something i feel in the car. i don't think mine is a worn CV joint. it honestly feels like a bad engine mount! but i replaced them
Old 11-17-2007, 09:25 PM
DUK DUK is offline
DUK's Avatar
Just curious, did you replace all 4?
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 11-18-2007, 05:09 AM
When I first got my car, I found that the rear engine mount bar was loose where it attaches to the engine. Make sure these mount bar bolts that go into the engine block are tight - and also that the engine to transmission bolts are tight. I've seen both problems.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-18-2007, 05:52 AM
i did replace all 4...and only the engine mounts looked like they had much give. i'll take a look today to make sure all the mounting brackets are secure and the engine to transmission bolts are tight....
Old 11-18-2007, 07:33 AM
jonbot's Avatar
Any news on this?
'95 993 C2
'73 911 Targa
'88 BMW M3
Old 11-18-2007, 07:08 PM
nope....didn't find anything. i checked all the mounting bolts and engine to tranny bolts. everyhing checked out ok.
mine only happens in first gear and in reverse but only when i release the clutch quickly. i guess its something in the transmission. have you replaced the engine mounts? it definitely helped the situation ALOT but didn't cure it all together...
Old 11-18-2007, 07:14 PM
