LinkBack | Thread Tools | Rate Thread |
What to do with the chrome when I put my 911T to sleep in the winter
What do you do with the chrome, when you store your car? My car is in a cold but dry garage. Thanks for your help
911 user
Clean, polish and rub down with a little vaseline on a rag. Use the wipe on, wipe off method.
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
Check out a motorcycle shop. They have PS1000(?) spray that inhibits corrosion. I've used on my HD a few times, but it is a ***** to clean off in the spring.
73 914-6, Vintage Spyder,05 997(sold), 04 Anniversary 911 #151(sold) 08 Beck Speedster #317 (sold) 76 911S (sold) 76 911 Targa (cut up & sold) 86 951 (sold)914-6 (sold) |
Junior Member
WD40 or any spray lubricant works well on any type of metal. It wipes off very easily. Just don't spray it on your rubber trim.
Cheers
Remember, it's not a lie if you believe it. |
Lots of pure wax is good, too (several coats allowed to dry between coats). Won't work with the other "soft" things mentioned, so it's one or the other. The others will just dissolve the wax.
