Typically, the platers I use in So. Cal charge a minimum fee of around $50 for a batch treatment - good for about 20-30 lbs. YMMV. Pre-clean all parts and don't include any non-ferrous parts in the mix. They will disappear in the chemical process.
Sherwood |
Tru6 Restoration & Design |
thanks for the info on the black oxide, and that I can choose plating colors. because the E is going to be more of a racer interpretation than a Pebble Beach restoration, I like the black, understated look. But I will defer to the plater's opinion on maximum protetection.As to inventorying, I just picked up an old, old typesetters cabinet on Craig's List, free! I have maybe 2000 compartments to fill. Will post what I find tomorrow.
Tru6 Restoration & Design Last edited by Shaun 84 Targa; 11-19-2007 at 02:58 PM.. |
Shaun, I might have a castellated nut for you. The project is going well, I'm actually working on it right now.
$190 for Yellow Cad plating...
Texas Precision Plating 3002 Benton Street Garland, TX 75042 972-4941547 Before: ![]() After: ![]() ![]() ![]() ![]() ![]() ![]()
I vote for yellow zinc as well - I just got a big bucket of parts back and they look pretty good. I glass bead blasted them before I ran them over to the platers to save a bit ont he cost.
Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
BTW, I forgot to mention (and really should have) that there is no lubricant at all in the cylinders, so if you are spinning it, please throw something in.
nice looking jewelry.
So I've been following these threads and the one thing I'm still unsure of is the best way to go from crusty, rusty, caked-on-greasy to clean enough for the plater. How do you prepare the stuff for the platers? I can't imagine the hours it would take to bead blast all that stuff. I've used a rock tumbler with great results, but that takes time, lots of time.
CConnor 73E targa 89 Coupe |
I cleaned mine in a parts washer, followed with Simple Green and ended with Eagle One Mag Cleaner (contains Hydrofluoric Acid). Then off to the platers.
FWIW, I did not pre-clean mine (although they came off a garage queen, and were not that bad). Both the yellow cad and yellow zinc came back looking like the pics above.
Confused
If you want to clean lightly rusty parts - toss in a container of coke overnight - Coca Cola does contain some phosphoric acid - just enough to take off surface rust overnight, and not enough to do major damage. You do need to degrease it first.
I am of course assuming the formula for coke is the same worldwide, but on good authority, it is. After that I would CAD plate it, those boxes of jewels look too good.
Squeaky brakes are safer.... 2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress 1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain |
Slumlord
We black oxide tooling where I work. In the summer it rusts just from finger contact.
CAD plate and live with the bling. |
Called AOTCO.
They don't do small jobs, but they let this fellow Reggie, also an auto enthusiast, come in and use the facilities. He's going to call back.
Shaun, When I had mine done, I went in person and hooked up with a fellow I had talked with over the phone (this was not a huge plating operation) who did it "on the side".
Talked with Reggie, he's the on the side guy.
Just did some chrome for a an old Ferrari he tells me.He charges by the hour, $50/hour, everything is hung, no basket/barrel work. figures it will be about $150 if I have everything done. I'm going to bring 2 batches up next week. What I need done versus everything I have. it will be a true CAD plate.
After talking wtih 2 platers here in MA, I'm going to go with
Texas Precision Plating 3002 Benton Street Garland, TX 75042 972-4941547 Thanks MyTurbo. Cleaning everything up this weekend and sending it down. Post Office has a $9 fixed price Priority Mail Box and I think everything I have will fit right in.
I "think" those Priority boxes are limited to 2lbs max (or at least they used to be). Don't know if you'll have that issue, but just FYI.
keith, the Post Office has what they call a Flat Rate Box. It measures 11" X 8.5" X 5.5" and costs $8.95 no matter how much it weighs. Perfect for shipping a pair of calipers BTW.
I went with Texas Precision because they were the only ones who asked if I had any grade 8 or greater bolts and springs, noting that these will have to be baked due to the enbrittlement thing.
Shawn - how did this turn out ??
Robert Williams 70' 911T |
Bob, sadly I haven't sent everything yet. Getting stuff plated is like a disease. It's no longer enough to plate just your nuts and bolts, EVERYTHING that was once shiny and new must be plated. then there's the sorting into types of pieces and then there's yellow CAD vs. silver CAD piles to segregate. and I have a few more pieces to take off the car I discovered just the other day. Sooooooo, I hope to get everything sorted, bagged, labeled and shipped by the end of the year.
Will let you know when it's done.
