-   -   Refreshing old hardware, keeping it rust-free (http://forums.pelicanparts.com/porsche-911-technical-forum/378117-refreshing-old-hardware-keeping-rust-free.html)
Shaun @ Tru6 11-18-2007 07:29 PM
I've been soaking several sets of 69 - 73 suspension nuts, bolts and miscellaneous hardware for some time first in mineral spirits and then in PB Blaster. Next step will be to wirewheel everything down to clean metal.
Any ideas on what I can do with it after this stage to help protect it from rusting again, especially after mounted in the car? I've lightly coated some parts with a thinned down layer of POR15, but it's not factory and looks out of place.
In the absence of CAD plating, is there something I can soak this stuff in to help keep it fresh?
and anyone have a rear hub castle nut I can buy? :)
http://forums.pelicanparts.com/uploa...1195442903.jpg
http://forums.pelicanparts.com/uploa...1195442950.jpg
http://forums.pelicanparts.com/uploa...1195442995.jpg
Danny_Ocean 11-18-2007 07:42 PM
Gibbs Brand is supposed to treat bare metal. I just bought some but haven't tested it yet.
robmog 11-18-2007 08:16 PM
shaun,
i don't know what your budget is but i've heard good things about the copy cad process. i plan on using it when i get to that point.
check this out.
http://www.caswellplating.com/index.html
bob
Robert Buchanan 11-19-2007 04:09 AM
Shaun,
Caswell has yellow chromate. Since your parts are alreay zinc plated you can simply "dip" your parts in yellow chromate to refresh them. It does not come out shiny like when new...but does have the correct color.
gsmith660 11-19-2007 04:52 AM
Might try Eastwood http://www.eastwoodco.com they have many different ways to blacken and anodize metal after you get it that clean may not be completely factory but will look good.
Shaun @ Tru6 11-19-2007 07:46 AM
THanks for all the great suggestions. I would send everything out to be Cad plated, but everything I've seen done is way too shiny. I want a factory look, but will be happy with an "industrial" one as well. The real end game of course is rust-free parts that stay that way.
What I wanted to do with the thinned POR15 was to just "stain" the hardware, but it was still too much. That said, this black oxide kit looks very attractive:
http://www.caswellplating.com/kits/black.htm
Simple, understated, effective all rolled into one.
dtw 11-19-2007 07:56 AM
Wire-wheeling individual bits of hardware is insane unless you are trying to restore smooth surface for concours work or extra-shiny bits. You're welcome to do that, and I do it to some stuff prior to plating. However before all that, just to get back to clean virigin metal, I whip up a strong batch of muriatic acid in a five gallon bucket. I soak all my pre-cleaned/degreased hardware in that. The crazed foaming tells you it is working, and it tickles when it splashes on your arm!
Try it, you will be absolutely amazed. Rinse thoroughly then dry quickly and they'll stay rust-free until you decide how to refinish them. Major time saver and cheap, too.
Porsche-O-Phile 11-19-2007 08:21 AM
Zinc plate?
JFairman 11-19-2007 08:29 AM
Phosphoric acid is the stuff for removing corrosion from bolts and hardware.
It foams too as it eats off the corrosion and old plating.
It's blueish colored and cheap. Home Depot has it in quart plastic bottles.
Think it's called Ospho...
Then have the stuff plated, plate it yourself, or spray paint it.
AirCooledExcellence 11-19-2007 08:38 AM
I cad plated my rear suspension components and fasteners. They came out like this:
http://www.zen78885.zen.co.uk/ForumP...ebuildGold.jpg
Almost a year later they have dulled down quite a bit and look great!
Tut 11-19-2007 09:14 AM
If you're simply talking about hardware, as opposed to suspension pieces, wouldn't it be as cheap, and a whole lot easier, simply to buy new hardware? Paticularly when you start thinking about all of the time you would be saving to do other things to the car.
911pcars 11-19-2007 10:08 AM
CAD plating is best, but there may be limited availability in your area due to EPA regs for cadmium. Gold zinc plating services are more common.
Whichever method you choose, I would recommend checking with your vendor on heat treating after the plating process. Some do, some don't. Hydrogen embrittlement is a byproduct of the process. It weakens the base material unless treated afterwards; not too critical on small fasteners; more important on suspension fasteners and other high-strength, high stress applications.
MHO,
Sherwood
KFC911 11-19-2007 10:40 AM
I had mine cad plated, and although "blingy" initially like ACE's pictures show, they do return to a more natural state unless you keep your car locked up in a plastic bag :). True cad plating is fairly hard to locate unless you can find someone who has been "grandfathered" in past the EPA regulations. Yellow zinc chromate is very close, and much easier to find a plater that will do that.
Shaun @ Tru6 11-19-2007 10:46 AM
I've got more than triple this with rear suspension and 5 cars worth of bits and pieces.
If the bling dissipates, I can go that route.
Any problem with shipping a box full of hardware somewhere in the country to have it all done once?
Any recommendations?
Approximate cost?
KFC911 11-19-2007 10:53 AM
When I sourced a metal plater locally, it was a "set fee" (I don't recall how much, maybe $125 or so), and I could have put as much stuff as possible in his cylinder shaped "cad tumbler" for the same price, so I'm sure it would vary greatly depending upon the plater. My 930 rotors wouldn't fit, so those he did in yellow zinc chromate on his rack system. Just a caveat...no matter how careful you and he are, I can almost guarantee that when the box returns, a few items will be missing :(. Fortunately, in my case is was just a few nuts & washers, etc. (I had pics, and counted everything before/after).
dtw 11-19-2007 11:01 AM
If the hardware is in a rough-textured state (as it will be after an acid etch or sandblasting), then you will not get a super-shiny result. No worries.
Cad plating is really hard to come by, and those who have found it aren't talking. Regrettably, my own plater won't even let me spread their information around. They are an industrial plater and don't want to deal with anyone but locals for hobbyist work.
Cad is nearly 10x more expensive than zinc - I was paying well over $1.50/lb for it, when zinc was to be had for $0.17/lb or less.
The warnings regarding hydrogen embrittlement are worth heeding, especially if you're getting suspension bits plated. It is not made-up and it is not a 'maybe' proposition. It WILL happen and your fasteners WILL break - the only 'maybe' is if it will happen at an inopportune time/place. Ensure that any quotes you get include the cost of baking. My plater provides me with a data sheet detailing the results of my work's bake process as documentation. I'd advise dealing with a plater who can do the same for you.
A google search will bear fruit for leads - BTDT.
Shaun @ Tru6 11-19-2007 11:18 AM
I've just ordered the Black Oxide kit.
When it come in, I'll go do some testing with muriatic acid, wire-brush, etc. and then the Black Oxide with some spare late rear shock mount bolts I have to see how it come out.
Will post results.
Tim K 11-19-2007 12:33 PM
Originally Posted by 911pcars (Post 3596697)
... I would recommend checking with your vendor on heat treating after the plating process. Some do, some don't. Hydrogen embrittlement is a byproduct of the process. It weakens the base material unless treated afterwards; not too critical on small fasteners; more important on suspension fasteners and other high-strength, high stress applications.
MHO,
Sherwood
Originally Posted by dtw (Post 3596812)
...The warnings regarding hydrogen embrittlement are worth heeding, especially if you're getting suspension bits plated. It is not made-up and it is not a 'maybe' proposition. It WILL happen and your fasteners WILL break - the only 'maybe' is if it will happen at an inopportune time/place. Ensure that any quotes you get include the cost of baking. My plater provides me with a data sheet detailing the results of my work's bake process as documentation. I'd advise dealing with a plater who can do the same for you.
I was told that the occurrence Hydrogen Embrittlement was a function of the carbon content in the parts. However, there is no direct correlation between, for example, the grade of a fastener and the carbon content. I did not know any of this and my local CAD plater did not suggest baking when I dropped off a load of suspension parts and fasteners. It's not worth the expense of determining the metallurgy. The car is long gone now, and I found this out much later. There were never any issues but next time I'm not taking any chances.
Tim
euro911sc 11-19-2007 12:37 PM
When I was an engineer in MA we used these guys a ton:
http://www.globalspec.com/Supplier/profile/AotcoMetalFinishing
They may not do CAD, but I'm pretty sure they did zink... It's an easy drive, right up 93 and over on 128... there may be others nearer to you, but Cambridge is pretty tight and the industrial part is getting smaller every day :( You should not have to mail it all out.
Best regards,
Michael
304065 11-19-2007 01:59 PM
Sean,
Black oxide doesn't have ANY corrosion resistance. Sure, you get a uniform black finish, but the corrosion resistance comes from being coated with oil, which also makes things shiny for a while. I know this because I've got a fair amount of experience with the Caswell Black oxide kit: the Studs on an early SWB engine case are all black oxide. And they are all, invariably, rusty. You can re-black them, but make sure you rinse well with water, or you'll get brown rust from the acidity of the solution. And then it won't be period correct. If you want black, you can get black zinc.
I agree with the crowd here, have everything plated in Zinc with a Yellow Chromate Conversion coating. This is what the factory did. Like I said, if you want black, there's even black zinc, or olive drab, or clear (like silver cad). Zinc plating exhibits MUCH higher corrosion resistance than any older-technology treatment.
When you wire wheeled it the plating came off. Now it's a sitting duck for R U S T. Gibbs is an interesting idea, but how would you ever keep every nut and bolt treated while assembled?
If I were you I would get every nut bolt washer and other piece of loose metal you could lay your hands, INVENTORY it like you're OCD and then send it off to the plater. It's amazing what a difference it makes.
911pcars 11-19-2007 02:24 PM
Typically, the platers I use in So. Cal charge a minimum fee of around $50 for a batch treatment - good for about 20-30 lbs. YMMV. Pre-clean all parts and don't include any non-ferrous parts in the mix. They will disappear in the chemical process.
Sherwood
Shaun @ Tru6 11-19-2007 02:51 PM
Best regards,
Michael
Thanks Michael, they are about 30 minutes away, I'll give them a call tomorrow. Cambridge industrial, heck MA industrial, is a memory sad to say.
Shaun @ Tru6 11-19-2007 02:56 PM
Originally Posted by john_cramer (Post 3597228)
Sean,
Geez John is there anything you don't know! :) thanks for the info on the black oxide, and that I can choose plating colors. because the E is going to be more of a racer interpretation than a Pebble Beach restoration, I like the black, understated look. But I will defer to the plater's opinion on maximum protetection.
As to inventorying, I just picked up an old, old typesetters cabinet on Craig's List, free! I have maybe 2000 compartments to fill.
Will post what I find tomorrow.
klaucke 11-19-2007 03:50 PM
Shaun, I might have a castellated nut for you. The project is going well, I'm actually working on it right now.
MyTurbo3.6 11-19-2007 04:23 PM
$190 for Yellow Cad plating...
Texas Precision Plating
3002 Benton Street
Garland, TX 75042
972-4941547
Before:
http://forums.pelicanparts.com/uploa...1195518047.jpg
After:
http://forums.pelicanparts.com/uploa...1195518071.jpg
http://forums.pelicanparts.com/uploa...1195518091.jpg
http://forums.pelicanparts.com/uploa...1195518108.jpg
http://forums.pelicanparts.com/uploa...1195518123.jpg
http://forums.pelicanparts.com/uploa...1195518149.jpg
http://forums.pelicanparts.com/uploa...1195518181.jpg
http://forums.pelicanparts.com/uploa...1195518193.jpg
andrew15 11-19-2007 04:23 PM
I vote for yellow zinc as well - I just got a big bucket of parts back and they look pretty good. I glass bead blasted them before I ran them over to the platers to save a bit ont he cost.
Regards,
Andrew M
http://forums.pelicanparts.com/uploa...1195518216.jpg
Shaun @ Tru6 11-19-2007 04:30 PM
Great, thanks Jonathan, hope your project is going well. I'm not going to plate these, so no rush on it. can't imagine bright gold nuts inside light ivory cookies.
BTW, I forgot to mention (and really should have) that there is no lubricant at all in the cylinders, so if you are spinning it, please throw something in.
Crachian 11-19-2007 04:32 PM
nice looking jewelry.
So I've been following these threads and the one thing I'm still unsure of is the best way to go from crusty, rusty, caked-on-greasy to clean enough for the plater.
How do you prepare the stuff for the platers? I can't imagine the hours it would take to bead blast all that stuff.
I've used a rock tumbler with great results, but that takes time, lots of time.
MyTurbo3.6 11-19-2007 05:53 PM
I cleaned mine in a parts washer, followed with Simple Green and ended with Eagle One Mag Cleaner (contains Hydrofluoric Acid). Then off to the platers.
KFC911 11-20-2007 03:40 AM
FWIW, I did not pre-clean mine (although they came off a garage queen, and were not that bad). Both the yellow cad and yellow zinc came back looking like the pics above.
V12man 11-20-2007 04:44 AM
If you want to clean lightly rusty parts - toss in a container of coke overnight - Coca Cola does contain some phosphoric acid - just enough to take off surface rust overnight, and not enough to do major damage. You do need to degrease it first.
I am of course assuming the formula for coke is the same worldwide, but on good authority, it is.
After that I would CAD plate it, those boxes of jewels look too good.
Porsche_monkey 11-20-2007 05:38 AM
We black oxide tooling where I work. In the summer it rusts just from finger contact.
CAD plate and live with the bling.
Shaun @ Tru6 11-20-2007 06:13 AM
Called AOTCO.
They don't do small jobs, but they let this fellow Reggie, also an auto enthusiast, come in and use the facilities. He's going to call back.
KFC911 11-20-2007 06:23 AM
Shaun, When I had mine done, I went in person and hooked up with a fellow I had talked with over the phone (this was not a huge plating operation) who did it "on the side".
Shaun @ Tru6 11-20-2007 10:55 AM
Talked with Reggie, he's the on the side guy. :) Just did some chrome for a an old Ferrari he tells me.
He charges by the hour, $50/hour, everything is hung, no basket/barrel work. figures it will be about $150 if I have everything done.
I'm going to bring 2 batches up next week. What I need done versus everything I have. it will be a true CAD plate.
Shaun @ Tru6 11-29-2007 10:02 AM
After talking wtih 2 platers here in MA, I'm going to go with
3002 Benton Street
Garland, TX 75042
972-4941547
Thanks MyTurbo.
Cleaning everything up this weekend and sending it down. Post Office has a $9 fixed price Priority Mail Box and I think everything I have will fit right in.
KFC911 11-29-2007 10:40 AM
I "think" those Priority boxes are limited to 2lbs max (or at least they used to be). Don't know if you'll have that issue, but just FYI.
Shaun @ Tru6 11-29-2007 11:33 AM
keith, the Post Office has what they call a Flat Rate Box. It measures 11" X 8.5" X 5.5" and costs $8.95 no matter how much it weighs. Perfect for shipping a pair of calipers BTW.
I went with Texas Precision because they were the only ones who asked if I had any grade 8 or greater bolts and springs, noting that these will have to be baked due to the enbrittlement thing.
http://forums.pelicanparts.com/uploa...1196364704.jpg
rw7810 12-26-2007 08:09 AM
Shawn - how did this turn out ??
Shaun @ Tru6 12-26-2007 08:40 AM
Bob, sadly I haven't sent everything yet. Getting stuff plated is like a disease. It's no longer enough to plate just your nuts and bolts, EVERYTHING that was once shiny and new must be plated. then there's the sorting into types of pieces and then there's yellow CAD vs. silver CAD piles to segregate. and I have a few more pieces to take off the car I discovered just the other day. Sooooooo, I hope to get everything sorted, bagged, labeled and shipped by the end of the year.
Will let you know when it's done.
