Broken motor mount, can it be welded?
In the process of dropping the motor today we found the motor mount broken, like the mount twisted when we were trying to get the bolts out. Here is a pic let me know what you think. I can get it welded at work and reinforced a little also or should it be replaced?
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Schleprock
Happens quite often. You can have that welded. Just clean it up good and make sure it's bent back into place square. The original part was welded to create the mount bar, so no big deal welding it back together. Just be sure there's good meat to weld on, and reinforce with additional plates if need be.
A good weld is obviously important!
Kevin L '86 Carrera "Larry" |
You know, I was thinking about it - do you think I broke it when I was trying to break the bolt loose?
Just kidding. I certainly hope I didn't break it!
Mike '84 Grand Prix White RoW Carrera |
Agree with KTL. That area sees mostly shear loads (except when breaking motor mount bolts loose of course), so a good weld should make it good as new.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
RETIRED
I have one sitting here on the shelf....make me an offer.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
It's a very common break when removing the old bolts, I once had one do the same thing. Welded it up and never looked back.
Schleprock
![]() That's how I broke mine. A local friend had the same problem. Darn bolt wouldn't let go and tore the bar. Next time I do an engine drop on an engine that's been undropped for a long time, i'll be heating the bolts up a bit to break them loose. Or just fire up on the impact wrench........
Hmmm, interesting. Sorry about that KC!
So do you recommend reinforcing it too? It certainly wouldn't hurt, would it? Where are the pics of the clean engine bay and tranny? I can't wait to see them!
I sent the pics to you about hour and a half ago, must got stuck in the line.....hre's one
I did the same exact thing. Here's what I did to fix and reinforce it. (plus I added some holes, there's nothing lighter than a hole, right?)
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Nice Duke, but I probably wont do the holes, I mean I have a Carerra with power seats and windows and AC and lots of other stuff that adds much weight. So I'll weight
on doing the holes untill I loose all the other stuff.Thanks for posting the pic, now I know exactly how to do the repair.
Great pics. Yeah, I just got them. Man, it cleaned up quite nicely! I'm impressed. Hopefully you'll be able to keep it that clean.
I can't wait to do mine next! Then again, that means I won't get to drive it. Not sure if I want to do that...
My suggestions. Reinforce the mount with additional material, top and bottom. Duke's version looks fairly rigid.
In addition, convert over to the early style, nut and bolt arrangement instead of the thread-on bolt. That way, With a nut to counter-hold, there's less twisting force on the ends when loosening and/or tightening the bolt. Adding lightening holes helps offset the increased material weight needed to reinforce the ends. Every little bit helps. Sherwood |
Sherwood, are you saying you could drill out the threads of the captive nut on the engine support and use a nut with a longer bolt?
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Sherwood |
