-   -   3.2 P&C'S ON A SC????????????? (http://forums.pelicanparts.com/porsche-911-technical-forum/37826-3-2-p-cs-sc.html)
hank911 02-26-2001 06:54 PM
HI FOLKS,GOT A QUESTION FOR ALL THOSE INFORMED PERSONS.CAN I PUT 10:1 COMP 95mm P&C SET ON MY 83 3.0.I UNDERSTAND THAT THESE MOTORS ARE "DIFFERENT" STROKES BUT THE BORE IS THE SAME.QUESTIONS,CAN I USE THEM,WHAT WOULD THE RESULTING COMPRESSION BE,ANY MACHINING,PRO'S AND CONS??????????????? THANKS IN ADVANCE,YOU GUYS HAVE REALLY ADDED ALOT OF PEACE OF MIND THESE LAST FEW MONTHS.PHP....
Early_S_Man 02-26-2001 07:38 PM
Hank,
The problem is the diameter of the '3.2' piston wristpins ... it is 23 mm vs. 22 mm for your SC rod. If you had your engine completely apart, I suppose you could have your rods bored and rebushed. Unless there is something wrong with your pistons, I don't think it would be worth the trouble. It certainly isn't a 'slip-in' swap, and the resulting compression ratio, somewhere between 9.5:1 and 9.7:1, doesn't seem to justify the trouble, either!
Warren Hall
1973 911S Targa
hank911 02-27-2001 04:18 AM
THANKS ADAM,NO MORE TIME SPENT THINKING ABOUT THIS ONE. AGAIN,THANKS. PHP...
