hank911
Guest
Posts: n/a
3.2 P&C'S ON A SC?????????????
HI FOLKS,GOT A QUESTION FOR ALL THOSE INFORMED PERSONS.CAN I PUT 10:1 COMP 95mm P&C SET ON MY 83 3.0.I UNDERSTAND THAT THESE MOTORS ARE "DIFFERENT" STROKES BUT THE BORE IS THE SAME.QUESTIONS,CAN I USE THEM,WHAT WOULD THE RESULTING COMPRESSION BE,ANY MACHINING,PRO'S AND CONS??????????????? THANKS IN ADVANCE,YOU GUYS HAVE REALLY ADDED ALOT OF PEACE OF MIND THESE LAST FEW MONTHS.PHP....
Old 02-26-2001, 05:54 PM
Early_S_Man
Guest
Posts: n/a
Hank,
The problem is the diameter of the '3.2' piston wristpins ... it is 23 mm vs. 22 mm for your SC rod. If you had your engine completely apart, I suppose you could have your rods bored and rebushed. Unless there is something wrong with your pistons, I don't think it would be worth the trouble. It certainly isn't a 'slip-in' swap, and the resulting compression ratio, somewhere between 9.5:1 and 9.7:1, doesn't seem to justify the trouble, either!
Warren Hall
1973 911S Targa
Old 02-26-2001, 06:38 PM
hank911
Guest
Posts: n/a
THANKS ADAM,NO MORE TIME SPENT THINKING ABOUT THIS ONE. AGAIN,THANKS. PHP...
Old 02-27-2001, 03:18 AM
