Metal Guru
911nut's Avatar
Varioram on a 3.0
A few years ago someone was putting a Varioram intake on a 3.0 motor. Does anyone know of anyone on the board who has done this?
Search function was no help
Thanks.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 11-19-2007, 04:49 PM
klaucke's Avatar
Randy Wells had or has a 2.8 w/ VarioRam in one of his '72s:
Old 11-19-2007, 05:14 PM
Jandrews's Avatar
Just how does that work exactly? My understanding was that the Varioram from the 993 motors was all about variable cam timing, i.e. a function of the cam and valves. How does this intake "work", and what does it do for a 2.8? Very interesting....
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 11-19-2007, 07:14 PM
It just varies the intake runner lengths/plenum volume. Probably not worth the added complication and weight.
Old 11-19-2007, 07:36 PM
Jeff Alton's Avatar
Jandrews, you are thinking of VarioCam.
I am sure Steve at Rennsport could shine some light on this as well.
Cheers
www.turn3autosport.com
Old 11-19-2007, 07:41 PM
I've seen & heard that car run and without question, its worth ALL of the incredible efforts that Randy & Chris Powell put into that combination.
Varioram intakes produce a very flat torque curve thats better than most ITB systems from idle to 6K.
Randy's Varioram motor has many custom internals that allow that 2.8 to make power to 8K.
Not cheap to be sure but like many things, you get what you pay for,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2007, 08:17 PM
I've followed Randy's car at Pacific Raceways, it is very fast. His 2.8 with the varioram makes fantastic torque and HP and it revs forever. The first time I saw it I mistook it for 3.6 conversion.
86 Carrera
70 914-6
Old 11-19-2007, 09:41 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Hm, I wounder if putting in a straight 993 engine wouldn't be cheaper compared to all that custom work required to get a varioram intake adapted to an earlier engine. Why would you want to do it unless your racing classification requires small displacement and doesn't penalize you for intake modifications?
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 11-19-2007, 10:36 PM
Ingo:
Racing classifications are the very reasons why Randy did the 2.8. That displacement was the class limit and they were looking for "maximum area under the curve".
Mission Accomplished, IMHO.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-19-2007, 11:28 PM
ischmitz's Avatar
Steve, that's what I thought - makes perfect sense
Old 11-20-2007, 02:11 AM
Sports Purpose 911 Driver
mjshira's Avatar
I bet that engine sounds awesome!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-20-2007, 06:10 AM
