What is path of this?
What is the path of the brake booster vacum line? There is a short peice coming off of the booster and going to a nipple in the body right near by maybe 3" to 4" away, from there does it end up in the tunnel and then to the engine?
85' Carrera 92' Mustang 5.0 02' Focus ZX3 08' FJ Cruiser |
Basically, there is a steel tube that runs through the tunnel. You should be able to see where it exits the tunnel near the throttle pedal and follow the path from there. See the attached picture.
JR
JR
Thank you very much that is fantastic, it does not get any better than that, a real life 3D diagram man that is exactly what I need and much more than I hoped for. again thanks Jeff
