Question Flaring Fender Question
I had my car lowered to Euro Height and Mechanic doing the alignment said I should flare my front fenders so that my tires don't rub. Since this is still pretty new to me, it sounded like I should have a body shop bend the inside lip of my fender in... is that right? Is this necessary? I have 205/50/16 on the front.
86 Garnet Red Cabriolet
Old 11-30-2007, 09:27 PM
Sports Purpose 911 Driver
mjshira's Avatar
I think he might have meant roll the fender lip, not flare. Flaring your car is a great move if you like that look. Just keep in mind you'll have to spend a considerable amount to get it done right.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-30-2007, 09:30 PM
Don Plumley's Avatar
For 205/50 you might need the fender lips rolled. If the paint is warm (to keep from cracking), it's a 10 minute process with a baseball bat. No biggie.
Don Plumley
M235i
Old 11-30-2007, 09:38 PM
Thanks for clarifying. Do most euro height cars roll the fender lips? So it is possible to do it yourself? I might try the baseball bat trick.
Old 11-30-2007, 09:39 PM
Tim K's Avatar
Please do a quick search if you are not familiar with the process
Here is a link showing a purpose built tool:
Aluminum bat for fender rolling?
Tim K
Old 11-30-2007, 10:01 PM
Thanks for the info and the link. I thought I would give it a try right away and made a little bit of progress. Heated up the paint with a blow dryer and used a wooden dowel. Much harder that I thought. I figure I'll roll the fender little by little until there is no rub from the tire. Thanks for the tips!
Old 11-30-2007, 11:15 PM
