WI wide body's Avatar
1986 Carrera cab top question:
Have a 86 Carrera Convertible that currently has a factory original "two piece" top. I read an ad on ebay where a seller was offering 993 "one piece" top that claims will fit and work on the 911 models. Is this true and/or anyone have experience with using the 993 tops on 911 Carreras? Txs.
Old 11-25-2007, 11:58 AM
3.2 CAB's Avatar
I have seen some of the earlier cabs that had the later style 1 piece top installed. As far as I know they will work, but the entire cab frame assembly has to be changed out also, not just the fabric. Is the top that you are asking about the entire cab assembly, or is it just the fabric?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-25-2007, 12:24 PM
That's a good point. Many people that might say they are interchangeable could mean the entire unit rather than just the top itself.
I was talking about using a fabric 993 top cover on the existing 1986 mechanism.
Old 11-25-2007, 12:54 PM
shahram's Avatar
There is a "one piece" 993 customized top for 911 and 964 cabs available.
And you don't need to change the frame or the mechanism, just replacing the tops. The only issue is that the vendor is located in Germany
Old 11-25-2007, 01:29 PM
That is what I'm looking for.
What is the name of that top?
Old 11-25-2007, 05:14 PM
shahram's Avatar
here you go:
http://www.ck-cabrio.de/Eigenentwicklungen.htm
Let me know if you need a translation.
Old 11-25-2007, 11:53 PM
Thanx for the info.
Old 11-26-2007, 12:00 PM
