AirBorne!
Masking Fuchs for painting centers - share your masking tips
Gents
I've searched the BBS, done my research and now I'm going to refinish my track wheels. I'm repainting the inside of the wheel black using rattle can Wurth. The lips I'll polish with PS21 stuff I bought from PP. My question is, Can someone please share with me the materials and technique for properly masking the aluminum, unpainted wheel lips? Any tips that someone can share with me? Pictures would be appreciated. Thanks Wellborn
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Black electrical tape works great for making curves. Also, fine line masking tape is useful.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
AirBorne!
Where do you get fine line masking tape?
use electrical tape! makes sure the tape is not cold.
Band.
instead of trying for an hour to make nice lines with electric tape (which is a fine idea), you could use wide blue painter's tape and "over-tape" the lip, taping into the black, then cut the line you want between the lip/black with a razor blade.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 11-25-2007 at 07:10 AM.. |
Nice tip, Gogar.
Fine line tape can be found at hardware stores. What I meant was to use thin width tape to get the fine lines, then use wider tape to cover the other areas. When I did my Fuchs a few years ago, I did it this way and they turned out very nice. My wife painted the center caps while I did the wheels.
masking Fuchs
You might try an auto paint supply store for masking tape.
I have some blue plastic tape similar to electrical tape but it's 1/4" wide, and very flexible. It is widely used in the industry , and leaves a sharp edge unlike plain masking tape. good luck |
I used eighth inch striping tape from Pep Boys, black electrical tape, and blue masking tape. Sand lightly with 600 after masking, then black self etch primer and Wurth satin. I also taprd the lug nuts and set them in place to prevent paint from getting on the mating surfaces.
Good Luck Joe ![]() ![]() ![]() ![]()
Joe Frantz 73 911 T |
Registered Cruiser
Just did a rough job on my winter Fuchs. Used electrical tape to train around the edge and then taped newspaper around the balance of the wheel. If you cut large arcs out of the newspaper it is very easy to mask. Took about 10 mins per wheel.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
AirBorne!
Gogar, excellent tip. Thanks to all for pixs, etc.
Anymore? wj
