Meguire's PlatX for Cab rear window?
Any one try PlastX on the plastic rear window of a Cab? I'm wondering if I should try it on mine.
Jeff
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 11-23-2007, 10:06 PM
Wickd89's Avatar
I use it and it is pretty good. Not perfect but it does improve the window. Also use microfiber cloth.
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 11-23-2007, 10:25 PM
Send a message via AIM to johncarlos2003
a trick i used on my audi was to fold a towell down into the top so the moisture doesn't sit beteween the plastic as it's folded and, in turn, "rot" and discolor.
worked pretty well! good luck!
john-carlos ynostroza
88 G50 coupe, black/black
Old 11-23-2007, 11:53 PM
SCWDP911's Avatar
My experience has also been that it will help with clearing up of light haziness, but not much help on anything major...
Shane
- 1984 928S
Old 11-24-2007, 12:04 AM
Wickd89's Avatar
Ditto.
2 towels on both sides of the clear window to protect from rubs.
PlatX also works on slight scratches on the gauges...
Old 11-24-2007, 08:35 AM
Nine9six's Avatar
Originally Posted by Wickd89 View Post
Ditto.
Same here, but it sure takes the spontaneity outta putting the top down.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-25-2007, 07:52 AM
So what would be a recommended "polish" for a cab window?
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 11-25-2007, 08:07 AM
naturally aspirated
Palum6o's Avatar
Have you tried Plexus for routine cleaning/moisturizing? I use it on my flat screen monitor and nav screen and it works really well.
Old 11-25-2007, 08:22 AM
Wickd89's Avatar
So true, but since it is a power top, it still only takes about 2 minutes. Not to bad....
Old 11-25-2007, 10:35 AM
Wickd89's Avatar
Also I always have one black towel on the back bench (on the inside), so after I unzip the window, I go out and lay another black towel on it and then power close.
Process is OK for an anal guy like me.......... ;-)
Old 11-25-2007, 10:37 AM
