-   -   Twin plug stuff. Need help to ID (http://forums.pelicanparts.com/porsche-911-technical-forum/379152-twin-plug-stuff-need-help-id.html)
pjv911 11-25-2007 12:41 PM
I found a bag of ignition parts marked twin plug dist parts. Inside I found 2 brass gears in the oem packages showing part # 547.09.248
Also found 2 caged bearing assemblies also in oem bag and with part # 900.052.007.00
Lastly there is a neat looking plate with two sets of points mounted but no part #. See pictures
Who has the knowledge to id this stuff?
http://forums.pelicanparts.com/uploa...1196023221.jpg
http://forums.pelicanparts.com/uploa...1196023242.jpg
http://forums.pelicanparts.com/uploa...1196023282.jpg
MBruns 11-25-2007 02:13 PM
points plate
that looks like the fuel injection trigger points for the 914-4
Mike Bruns
pjv911 11-25-2007 02:32 PM
Mike Bruns
That would make sence because the terminal plug looks kinda new to be a twin plug part. Do you know for sure or does it just ressemble a 914/4 setup?
What about the bearings?
MBruns 11-25-2007 03:23 PM
points
There should be a bosch part # on the piece something like (0 xxx xxx xxx x )
post the # and we can figure it out. I can't tell by the pic what they are.
Mike
