-   -   Dash replacement alternative (http://forums.pelicanparts.com/porsche-911-technical-forum/379545-dash-replacement-alternative.html)
richde 11-27-2007 11:34 AM
Has anybody tried one of these out?
PEL-PP-900626 Coverlay Dash Cover
http://www.pelicanparts.com/cgi-bin/...verlay_911.jpg
Looking at a car and it's perfect, except I really don't like the leather on the dash or the headliner, but that's a different saga. I looked up dash replacement, and whoa, the only thing worse is replacing the headliner... If you took the carpet and seats out, couldn't you dye the headliner? Or do I learn to live with brown and tan? Tan isn't that bad, I'm just not sure if I'm crazy about the brown.
Bench-Racing 11-27-2007 12:00 PM
I looked into having my ivory headliner sprayed black by a long time friend that does Jag/Mercedes/Porsche/etc interior repair and he said he can't do a headliner. As far as the dash cap, some guys like to slam them but I really don't understand why. For under $100 and 15-30 minutes time you can have a great looking dash vs. $1000+ to repair/replace the factory dash? They work great but are only available in black. Several different companies make them, we deal with "DashTop", a slightly different design execution then PEL-PP-900626. Good luck with your project.
Regards,
Charles
http://forums.pelicanparts.com/uploa...1196193559.jpg
Nitrometano 11-27-2007 02:56 PM
How that dash pad is installed? It need be glued or is a simply put over the old one and thats all.
CrossT 11-27-2007 03:31 PM
These come in lots of colors. I had one on a previous car and it was very good WRT fit. Color was close, but not perfect. I chose to just lay it there and not glue it, but in my case [an 86] the larger def vent screwed it down tight anyway. 85 and earlier may need glue.
gtihop 11-27-2007 03:50 PM
I've got one in my 83 911. They look sort of cheap- like a plastic dash on an old nissan or honda! It will do until I redo the original dash. it's glued in and does fit fairly well.
DW SD 11-27-2007 05:24 PM
Why not cover with black alcantra?
Mitch Leland 11-27-2007 09:12 PM
They have vinyl spray paint in a variety of different colors that works very nicely on the dash covers. I don't have the brand name in front of me, but I can get it if you want it.
Wayne 962 11-27-2007 10:14 PM
If done right, the plastic caps can look very good. It all depends upon the quality of the installation though...
-Wayne
richde 11-27-2007 10:18 PM
-Wayne
The care taken on the rear edges being the most crucial?
Evans, Marv 11-27-2007 10:37 PM
When I bought my '72, it had a dash cap. The seller didn't inform me of course, and it was a while before I paid enough attention to notice it. So they're not so bad for the price. I bet if you put on on intending to keep it on until you bought a new replacement, the cap would end up being on for a long time.
richde 11-29-2007 10:03 PM
Regards,
Charles
Did he say why he couldn't do the headliner?
tcar 11-30-2007 08:28 AM
Actually, no. The front edge, against the windshield is actually more visible and harder to 'get right'. That's where it can ripple and it really shows.
They are made well enough that the rear edge fits very well.
I think the good ones (pelican's) fit and look very well; not like leather, but...
My '79 had a big gouge in the dash and it was an easy fix until I could get a new dash (which I never did).
porschefool 11-30-2007 09:59 AM
I put one on my '79 928...spiffed it right up.
Didn't use enough glue at the windshield so it started to ripple in the hot summer, but a new dash was worth about half of the whole value of the car, so a no-brainer.
spuggy 11-30-2007 10:45 AM
My '86 944 had the typical cracking on the dash and a plastic dash cover. Took a while to notice it, color and grain match was pretty darn close...
I'm glad the PO didn't glue it down - I'd get marginally better demisting if I took it off in the winter. Then again, maybe if it'd been fitted properly, it'd have lined up perfectly with the vents...
TargaFlorio 11-30-2007 10:57 AM
That's what I did with mine. No more glare!
http://forums.pelicanparts.com/uploa...1196449023.jpg
Cheers,
n.
_
http://nicolashunziker.com
jtfreels 11-30-2007 11:59 AM
I've got the plastic cover in my Targa, put in by the PO. I don't know what problems the real dash has.
On the other hand TargaFlorio did you do that covering yourself? If so any info on the process?
Looks nice.
Jay
TargaFlorio 11-30-2007 01:27 PM
Jay,
I'm fortunate to have a two-piece dash (1968 Model). I bought the alcantara over the internet. I did the smaller dash piece (the one that butts up to the windshield) myself.
I had the other piece done professionally by a local upholsterer. I think I paid like 40 bucks or so.
Cheers,
n.
_
jtfreels 11-30-2007 02:47 PM
Thanks for the info.
Jay
4flyboy 11-30-2007 03:29 PM
The PO did my '85 in Blue Cap to match the interior. It's a close match but.......plastic is plastic. I have a local guy (So. Cal) whom I've used before on seats quote me $400 to cover it in blue matching vinyl with stitching to match the original. He says he could do it in leather but it wouldn't last. He also quoted me $400 per on seats in blue leather......I'm tempted. He's in the hood but does very nice work.
Scott
BRB-83-911SC 12-02-2007 07:07 PM
Scott
Scott - do you have a picture of the blue plastic dash cap? I have a blue leather dash (trashed) covered by what appears to be a plastic cap covered with yet more leather (which fits poorly and is very warped). So, I am considering removing that and trying a blue plastic cap until the budget allows for dash replacement. Thanks.
