Dash replacement alternative
Has anybody tried one of these out?
PEL-PP-900626 Coverlay Dash Cover ![]() Looking at a car and it's perfect, except I really don't like the leather on the dash or the headliner, but that's a different saga. I looked up dash replacement, and whoa, the only thing worse is replacing the headliner... If you took the carpet and seats out, couldn't you dye the headliner? Or do I learn to live with brown and tan? Tan isn't that bad, I'm just not sure if I'm crazy about the brown. |
I looked into having my ivory headliner sprayed black by a long time friend that does Jag/Mercedes/Porsche/etc interior repair and he said he can't do a headliner. As far as the dash cap, some guys like to slam them but I really don't understand why. For under $100 and 15-30 minutes time you can have a great looking dash vs. $1000+ to repair/replace the factory dash? They work great but are only available in black. Several different companies make them, we deal with "DashTop", a slightly different design execution then PEL-PP-900626. Good luck with your project.
Regards, Charles
Charles 1970 911t 1962 356 S90 1964 Safari Rally Comet Editor www.Bench-Racing.com |
How that dash pad is installed? It need be glued or is a simply put over the old one and thats all.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
These come in lots of colors. I had one on a previous car and it was very good WRT fit. Color was close, but not perfect. I chose to just lay it there and not glue it, but in my case [an 86] the larger def vent screwed it down tight anyway. 85 and earlier may need glue.
I've got one in my 83 911. They look sort of cheap- like a plastic dash on an old nissan or honda! It will do until I redo the original dash. it's glued in and does fit fairly well.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
Why not cover with black alcantra?
1971 RSR - interpretation |
They have vinyl spray paint in a variety of different colors that works very nicely on the dash covers. I don't have the brand name in front of me, but I can get it if you want it.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Author of "101 Projects"
If done right, the plastic caps can look very good. It all depends upon the quality of the installation though...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
When I bought my '72, it had a dash cap. The seller didn't inform me of course, and it was a while before I paid enough attention to notice it. So they're not so bad for the price. I bet if you put on on intending to keep it on until you bought a new replacement, the cap would end up being on for a long time.
Marv Evans '69 911E |
Actually, no. The front edge, against the windshield is actually more visible and harder to 'get right'. That's where it can ripple and it really shows.
They are made well enough that the rear edge fits very well. I think the good ones (pelican's) fit and look very well; not like leather, but... My '79 had a big gouge in the dash and it was an easy fix until I could get a new dash (which I never did). |
I put one on my '79 928...spiffed it right up.
Didn't use enough glue at the windshield so it started to ripple in the hot summer, but a new dash was worth about half of the whole value of the car, so a no-brainer.
1984 928s 5 speed |
My '86 944 had the typical cracking on the dash and a plastic dash cover. Took a while to notice it, color and grain match was pretty darn close...
I'm glad the PO didn't glue it down - I'd get marginally better demisting if I took it off in the winter. Then again, maybe if it'd been fitted properly, it'd have lined up perfectly with the vents...
'77 S with '78 930 power and a few other things. |
I've got the plastic cover in my Targa, put in by the PO. I don't know what problems the real dash has.
On the other hand TargaFlorio did you do that covering yourself? If so any info on the process? Looks nice. Thanks Jay
2002 Boxster Speed Yellow |
Jay,
I'm fortunate to have a two-piece dash (1968 Model). I bought the alcantara over the internet. I did the smaller dash piece (the one that butts up to the windshield) myself. I had the other piece done professionally by a local upholsterer. I think I paid like 40 bucks or so. Cheers, n. _ http://nicolashunziker.com |
Thanks for the info.
Jay
The PO did my '85 in Blue Cap to match the interior. It's a close match but.......plastic is plastic. I have a local guy (So. Cal) whom I've used before on seats quote me $400 to cover it in blue matching vinyl with stitching to match the original. He says he could do it in leather but it wouldn't last. He also quoted me $400 per on seats in blue leather......I'm tempted. He's in the hood but does very nice work.
Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Brian 84 928S Euro |
