engine questions
On an impulse I bought a 3.2 motor recently. The engine number is 63E06074 witch I believe means its a 84 Euro motor.
I have no real history except what the seller told me. It was suppose to have been out of a 70k mile car that was wreaked. The original buyer was able to hear it run before it was pulled. It was going to go into a 914. Does this look like the factory sealant. It looks a little sloppy and I was wondering if the motor has been opened up in the past. http://forums.pelicanparts.com/uploa...1196199064.jpg http://forums.pelicanparts.com/uploa...1196199098.jpg http://forums.pelicanparts.com/uploa...1196199126.jpg Thanks. |
Is that all the way down the case seam as well? It looks like RTV, and I didn't find any RTV on my engine during the teardown. You often times use locktite 574 on the case halves, however it drys to an darker orange color.
I have my engine down to the case right now and there is no sealant spooged out like that.
That is not factory.
I'm honestly surprised that the case didn't leak. I would tear it down just based on what I see there, you don't know how many other mistakes were made.
I was just curious. Any suggestions on what I can do to check it out while its out. |
| All times are GMT -8. The time now is 04:40 AM. |
