CT944's Avatar
No drain plug in case cover?
Changed the oil today, and had to take the lower cover off as there was no drain plug. I took off the 8 screws and dumped the remaining oil. Not bad, but a pain in the neck. Good news was the screen was clean and the gasket was like new. I cleaned up the cover and reinstalled.
Next time I change the oil, I may replace this cover with one that has a drain plug.
Is this common to not have a plug?
2007 997 TT
1992 500e
Old 11-28-2007, 10:27 AM
Greek55's Avatar
The plug makes it a lot easier and faster. I dont understand why they quit using the plug in the sump plate.
Smoke
1982 911SC Rosewood
SCWDP # 0097
Old 11-28-2007, 01:16 PM
sudo apt-get purge 930
equality72521's Avatar
Just look for a used one.
--clutch-monkey
Old 11-28-2007, 01:20 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Factory mentality was people were just draining the oil from the sump and NOT removing the screen to clean it. By removing the drain plug and making it a solid plate, you now have to remove the whole plate to properly change the oil which would force you to clean the screen. Just what I was told by a factory tech way back when.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 11-29-2007, 09:09 AM
Irrationally exuberant
ChrisBennet's Avatar
Mainely By Design make a nice aluminum one. I think Pelican sells it. I would a avoid a used (stock) one as they are subject to getting bent over the years and leaking.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-29-2007, 10:37 AM
This is the Mainely that Pelican carries.
http://www.pelicanparts.com/catalog/images/mainely/oil_sump.JPG
Pelican carries several models of these; for turbo, etc.
Old 11-29-2007, 10:45 AM
There is a clearance issue with the cover that has the drain plug IF you have a turbo, Carrera, or later oil pump that has the screen built into the pump. The drain plug contacts the screen and the cover cannot be properly installed. Mainely makes a cover that has the needed clearance with a drain plug that can be added, but when I had this on my 2.7 (the engine had been rebuilt with a Carrera oil pump) it always leaked, which was likely due to the warping of the the magnesium case.
Old 11-29-2007, 11:06 AM
