-   -   Here we go again! Zuffenhaus MS RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html)
ktr6 02-02-2024 04:30 AM
Brake line work has begun, new hard lines, using the old ones as templates:
http://forums.pelicanparts.com/uploa...1706876224.JPG
Getting an idea of the bends to get the lines into the rack n pinion tunnel. This is the driver side:
http://forums.pelicanparts.com/uploa...1706876404.JPG
Passenger Side:
http://forums.pelicanparts.com/uploa...1706876500.JPG
Main line flared and finished:
http://forums.pelicanparts.com/uploa...1706876747.JPG
ktr6 02-02-2024 04:48 AM
Feed Line for the brake splitter:
http://forums.pelicanparts.com/uploa...1706877833.JPG
Pics of the original lines/brake/clutch masters for reference:
http://forums.pelicanparts.com/uploa...1706877927.jpg
Two views of what we have so far:
http://forums.pelicanparts.com/uploa...1706877979.JPG
ktr6 02-02-2024 09:34 AM
Parking brake handle arrived today for restoration:
http://forums.pelicanparts.com/uploa...1706894645.JPG
Picture of the original:
http://forums.pelicanparts.com/uploa...1706895205.jpg
ktr6 02-04-2024 05:59 AM
Sunday Update
Small update, control arms and crossmember cleaned/blasted/painted:
Before:
http://forums.pelicanparts.com/uploa...1707054993.JPG
After:
http://forums.pelicanparts.com/uploa...1707055061.JPG
ktr6 02-06-2024 05:14 AM
Rear Parking Brake
Started working on getting the rear parking brake sorted out. From what we can tell the RSs with lug nuts used the typical brake shoe 911 rear emergency brake while the cars with center locks use the "clothes pin" style rear e brake. This build will be using the Zuffenhaus 930 style calipers that conveniently are premade to mount the clothes pin style setup. AASE currently offers a kit that is made to work with the Zuffenhaus made caliper.
AASE kit to be installed:
http://forums.pelicanparts.com/uploa...1707225015.JPG
Gus Berges 02-06-2024 05:19 AM
Is there a target date for completion? Just curious...
Will this be a static display, Pebble Beach Concours, cars & coffee, or tracked? Asking simply because of the level of details that are going into this car and the time it has taken so far to complete such details.
ktr6 02-06-2024 07:38 AM
Hi Gus,
Great question, nothing specific with regard to a completion date, my hope is before the end of the year including the sorting that will be required to get this running well. It will be interesting to see if its possible to make the slide valves perform well on the street.
Plan is to use the car for PCA events/C&C/and 7 tenths DE driving. I live near tail of the dragon, definitely planning on some mountain weekend trips!
ktr6 02-06-2024 03:41 PM
Pics of how it should mount from the AASE website:
http://forums.pelicanparts.com/uploa...1707262871.jpg
ktr6 02-07-2024 05:27 AM
Mounting bracket included with the kit:
http://forums.pelicanparts.com/uploa...1707312304.JPG
Mounting point on the caliper for the bracket:
http://forums.pelicanparts.com/uploa...1707312384.jpg
ktr6 02-07-2024 05:35 AM
When we went to install the mounting bracket that came with the kit it was discovered that it wasn't wide enough for our aftermarket rotor which is 32mm thick. The kit is made for the stock 930 rotor which is 25mm or less. Ended up having to fabricate a wider bracket to fit our rotor:
http://forums.pelicanparts.com/uploa...1707312785.JPG
http://forums.pelicanparts.com/uploa...1707312785.jpg
911 tweaks 02-07-2024 07:53 AM
Nice…!
That’s one meaty rotor……..!!
scootermcrad 02-12-2024 08:20 AM
@ktr6 Oh man! Great to see an update! Glad to hear there is momentum, as well.
Has this car been moved from North Carolina?? I see your location has changed to Knoxville.
Bill Verburg 02-12-2024 01:40 PM
hmm
930 used 304x32mm front and 309x28 rear rotors, only the '74-77 930 used the 911 size rotors 20mm rotors
afaik the same sizes as the '73/74 RSR
here's a very original '74 934
front
http://forums.pelicanparts.com/uploa...1707773521.JPG
rear, not sure if there is a parking brake
ktr6 03-14-2024 04:57 PM
Steering Rack
Small update, steering rack and crossmember are cleaned up and ready to install!http://forums.pelicanparts.com/uploa...1710460621.jpg
ktr6 03-30-2024 07:04 AM
Clutch Install
The clutch still needed to be installed so got the car on the lift and dropped the engine:
http://forums.pelicanparts.com/uploa...1711807092.JPG
Parts ready for install:
http://forums.pelicanparts.com/uploa...1711807227.JPG
Flywheel installed and marked:
http://forums.pelicanparts.com/uploa...1711807359.JPG
ktr6 03-30-2024 07:08 AM
Clutch and PP finished up:
http://forums.pelicanparts.com/uploa...1711807651.JPG
ktr6 03-31-2024 04:51 AM
Caliper and parking brake parts ready for assembly:
http://forums.pelicanparts.com/uploa...1711885660.JPG
Both sides installed:
http://forums.pelicanparts.com/uploa...1711885765.JPG
Pic from below so you can see how the pad fits etc:
http://forums.pelicanparts.com/uploa...1711885865.JPG
lateapex911 03-31-2024 02:40 PM
Those calipers are so cool. The parking brake though...pretty sketch LOL. Not Porsches best, but I get the situation and the era and the goal....
rickcperry 04-03-2024 05:42 AM
This car is going to be fantastic! Great pics with descriptions! lol
ktr6 06-15-2024 10:30 AM
Parking brake handle restoration
http://forums.pelicanparts.com/uploa...1718472008.JPG
