73.5 CIS with a loose wire
I found this loose white wire near the fuel line on the left side engine compartment. Does anyone know, off hand, what it goes to? TIA
Old 11-28-2007, 08:48 PM
HarryD's Avatar
I have that one too and I have no clue what it is for. I have been looking for the wire that feeds the rear licence plate lamp tho'.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-28-2007, 10:28 PM
Loose white wire
Well maybe it isn't used for anything so we don't have to be concerned that something is disconnected! : )
Old 11-30-2007, 10:43 PM
I'd check it with a volt meter or test light to see if it controls your rear window defoger
Old 12-01-2007, 07:29 AM
kodioneill's Avatar
look at a schematic
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-02-2007, 08:03 AM
Kodioneill
That's such wise advice. I looked and couldn't find a white wire. Do you have any other thought provoking idea's???
Old 12-02-2007, 08:07 AM
0n a 1973 911T CIS (so called 1973.5 911T) car there are two white wires connected to terminal D of the CDI unit (located near the area captured in the posted image). One of these wires connects to terminal 1 (ground) of the ignition coil and the other to the ground side of the ignition breaker points. One of these may be the loose wire under discussion; since they are there to ensure a good ground connection the system could operate with one of them disconnected.
If there are already two wires connected to terminal D of the CDI unit then my conjecture is incorrect.
Note that some of the wire colors can fade in time and appear to be another shade - especially in dim light; grey can appear to be white.
The license plate lights on a 1973 are fed with a grey wire but there are no breaks or connections in this wire in the vicinity of the fuel lines.
There is a good color wiring schematic for the 1973.5 911T here on the Pelican Parts website and an adequate B&W one in the Haynes Porsche 911 Automotive Repair Manual. The use of these in conjunction with physcial inspection of the wiring on the car can illuminate and answer most wiring questions.
Old 12-02-2007, 09:15 AM
Warren Hall Student
Bobboloo's Avatar
If it's white then it is probably one of the wires Jim describes. If it's grey then it's probably for the license plate lights that are in the decklid.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 12-02-2007, 09:57 AM
kodioneill's Avatar
he looked and couldn't find one. i found it but i'm not telling you cause your a wise guy.
1982 chiffon 911sc
Old 12-02-2007, 10:01 AM
Band.
Please go back to whatever Camaro forum you came from. We like each other over here.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-02-2007, 10:06 AM
HarryD's Avatar
Jim,
I have looked and looked and cannot find a loose wire in the vicinity of my wire to the licence plate lamps. Where exactly should I find this connector?
I have only one ground on my CDI box, Am I correct in noting that there should be a second from somewhere? If so, I have no unconnected wires in the vicinity of my CDI box.
If you have them, a few pictures may help illuminate the issues at hand.
Harry
2020 MB E350 4Matic
Old 12-02-2007, 10:22 AM
