-   -   Advise on how to remove Engine Electronics Plug (http://forums.pelicanparts.com/porsche-911-technical-forum/380212-advise-how-remove-engine-electronics-plug.html)
Dadofour 12-01-2007 10:36 AM
While I have the engine and transmission out for a transmission rebuild and an engine cleanup, I want to paint the engine compartment. I am removing all of the wires etc to get a good paint job, and I cannot figure out how to remove the engine electronic plug without damaging it.
I was hoping you might know the trick.
http://forums.pelicanparts.com/uploa...1196534167.jpg
john walker's workshop 12-01-2007 10:55 AM
drill the pop-rivets and re-rivet after painting. if you just want to remove the plastic part, push down and slide. takes some effort.
Dadofour 12-01-2007 12:42 PM
Thanks John. I found that if you press up on the front underside the whole thing can be slid out. Thanks. I just needed your post to know if could be done to play around enough.
Than
