DByers's Avatar
Wheres the RELAY?!?!?
Ok, I know there is a relay for my 71 wipers for the low med fast action, but where? I have searched behind all the gauges and dash. I have pulled the wiper assembly to look and nothing that I can see. Its in the wiring diagram but where is it in the car?
TIA
Dan Byers
Old 12-03-2007, 06:41 PM
Dan,
I don't believe you are going to find a wiper relay.
From what I can tell from the schematic posted on the Tech Info center for '71's there is no relay.
All controlled from the stalk switch. #30 on the print.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 12-03-2007, 08:07 PM
DByers's Avatar
Damn, I think your right. That means either the motor or the stalk is toast and that means $$$. I was hoping for a relay. The stalk will be pulled and cleaned but it already tested out fine and then that only leaves the motor.
Thanks, 2.7Racer
Dan Byers
Old 12-03-2007, 08:18 PM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Dan this might be a dumb thing to point out but I had a wiper problem that turned out to just be corrosion on the fuse in the fuse block. The wipers wouldn't work no matter how much I moved the stalk or use swear words in their general direction. All it took was a little cleaning.
One of these days I'm going to restore my fuse panel like Shaun 84 Targa did on his car.
-Jess
Old 12-03-2007, 09:26 PM
