Guest
Posts: n/a
Due to the vibration in the steering wheel around 100 km/h with the new wheels I'm going to have them balanced while on the car.
I thought that this would probably solve the problem, but now my collegue who's a mechanic claims that it will not be a perfect solution. According to him the wheels are in great danger of coming out of balance as soon as I accelerate or brake hard. Can that really be correct? Anybody out there with experiences or general knowledge? I'm being annoyed by this wheel problem ![]() [This message has been edited by Mikkel (edited 03-07-2001).] |
Guest
Posts: n/a
Mikkel, Good wheels should not do this! If you have the opportunity, see if you wheels are turning with no runout, like a warped rotor does. You could mount the wheels on the back and lift the backend. Let the engine turn the wheel at moderate rpm and check for trueness, like a bike rim. It could also be the tires. Sometimes you get a bad one that can't be balanced. As far as this balancing on the car stuff, It sound like an effort in futility. Should'nt have to be this hard!
------------------ 8 9 9 1 1, The last of the line. |
