Guest
Posts: n/a
Car will not crank -- battery is charged, all lights , warning and otherwise, work and are strong. Car will not turn over -- no clicking or any noise from the engine compartment. Any ideas would be greatly appreciated
Guest
Posts: n/a
Ideas to check out:
Starter Ignition switch/relay Ignition Cut-out relay for Alarm system Just some things that popped into my head. Sorry I can't tell you where these are located on your car (except for the starter), since mine is a bit older. Nick. ------------------ _ ______ _ Nick Shumaker 1982 911SC Coupe |
Guest
Posts: n/a
Fuses and relays in the passenger side of front compartment near windshield. Pop the cover and the contents and location of the relays should be noted by numbers on the inside of the cover.
