-   -   Having trouble shifting (http://forums.pelicanparts.com/porsche-911-technical-forum/38097-having-trouble-shifting.html)
JWDuffett 03-09-2001 01:25 PM
I am having trouble shifting. I can't get the darn thing in 1st gear or 2nd. It's like the left side of the gear box is not there.
Can start out in 3rd and make it to 4th and 5th. Any Ideas?
josh912 03-09-2001 02:00 PM
I had the same problem and it was the shift coupler bushings. I was going for 4th gear when it broke and instead I went into 2nd. Now that will get your heart pounding! http://www.pelicanparts.com/ultimate/wink.gif The bushings are only about $20 and are easy to replace. For the mean time however, you can use a small piece of PVC pipe with rubber on the outside for a snug fit. OWrked for me!
Joshua Harrison
1968 912 Coupe
